Apogee10's avatar
Mar 08, 2021
Netgear R7000 question
My desktop is hardwired to my Netgear-R7000P router and the network is identified as Network 3. My printer is connected to the router via wifi and the network is identified as Netgear02. I cannot print becasue of the isolation of the two networks. How can I link the two networks so I can print?
Earl
  • If you  mark it solved, it might make it easier for the next person with this issue.
