jah2nd
Mar 31, 2021Follower
Netgear R7000 reboot and reset issues
I have read many discussions on the Nighthawk A7000 constantly rebooting and/or users unable to reset. Solutions range from the recycle bin to a complicated software update - which of course does not work if the router will not reset. I found a very simple error / solution after an hour of aggravation: I had reversed the AC adapters for the CM700 and the A7000. The A7000 needs at least 2.5 amps output (P/N 332-10758-01). The 1.5 amp adapter worked ok for quite awhile, but when this issue arose, and I realized / corrected the error, the A7000 booted up correctly and the reset button worked.
No RepliesBe the first to reply
