Orbi WiFi 7 RBE973
Reply
Netgear R7800 Firmware 1.0.2.78
Jellev
Tutor
Re: Netgear R7800 Firmware 1.0.2.78
+1 also in AP-mode.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 26 of 42
nasilis
Tutor
Same here. AP mode.
Did downgrade with resets to versions .78, .76 and .74., same rebooting issue
.68 works fine
Message 27 of 42
paillassou
Apprentice
Smiley Frustrated
I do not understand why the NETGEAR development team
persists in continuing on this series of firmware
1.0.2.72
1.0.2.74
1.0.2.76
1.0.2.78
that do not work properly ...Smiley Mad
Message 28 of 42
supermarco
Tutor
AP Mode, DFS Channel 64, USB HDD attached,
Experiencing random reboots as well.
I just downgraded to .68. If I see another reboot, I'll let you know.
EXACLTLY SAME PROBLEMS WITH v1.0.2.74 / v1.0.2.76 / v1.0.2.78
Router reboots randomly
Wifi drops in AP MODE /
unable to use AP MODE
R7800 v1.0.2.78 firmware always contains BUGS
Even with fresh and clean install...
Reset the router. Still the same problem.
Back to firmware v1.0.2.68 and everything is OK again
Message 29 of 42
Message 30 of 42
Message 31 of 42
nasilis
Tutor
No reboots for a couple of hours on .80
Message 32 of 42
nasilis
Tutor
No reboots on version .80 for more that 12 hours. Previously it rebooted multiple time in first 30 minutes after install.
I guess it is fixed at least for me.
Message 33 of 42
paillassou
Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.80 issues
Netgear R7800 Firmware v1.0.2.80 contains BUGS
EXACLTLY SAME PROBLEMS and random REBOOT !!!
with firmware v1.0.2.74 or v1.0.2.76 or v1.0.2.78
R7800 reboots randomly after boot up .... works 2 minutes and reboot...
WIFI drops in AP MODE / unable to use AP MODE
R7800 v1.0.2.80 firmware always contains BUGS ...
Even with fresh and clean install :
Reset the router = push reset button for 10s... Still the same problem.
DO NOT UPDATE FIRMWARE v1.0.2.80 R7800
Back to firmware v1.0.2.68 and everything is OK again...
NETGEAR R7800 FIRMWARE v1.0.2.80 issues - NETGEAR Communities
Message 34 of 42
That's a "partial" reset.
Message 35 of 42
paillassou
Apprentice
Could you explain how do a complete HARD RESET please ?
THANKS
My R7800 was on v1.0.2.68... works fine...
i've done a RESET by pushing button for 10 sec...
R7800 restarts v1.0.2.68, launch GUI 192.168.1.1, assistant starts, and run upgrade to fw v1.0.2.80
R7800 restarts the new v1.0.2.80... and enter all manual parameters  (AP mode, wifi ssid, key ... )
the R7800 works for 5 minutes... wifi drops ... internet drops.... and R7800 reboots...
Believe me, honestly, it's not a game, for me, to upgrade... week after week...
THE ONLY THING i would is that my R7800 works fine, with AP mode, with the latest firmware...
BUT .... since fw v1.0.2.72, v1.0.2.74, v1.0.2.78, v1.0.2.80
it's IMPOSSIBLE !!!!
Message 36 of 42
THANKS
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
Message 37 of 42
nasilis
Tutor
Me again. .80 started to reboot. I think additional active users triggers reboot issue.
Back to .68
Message 38 of 42
paillassou
Apprentice
@michaelkenward
RESET
https://www.downloads.netgear.com/files/GDC/R7800/R7800_UM_EN.pdf
page 171
Factory Settings
You can return the router to its factory settings. Use the end of a paper clip or a similar object
to press andhold the Reset button on the back of the router for at least seven seconds.
The router resets and returns to the factory configuration settings shown in the following table.
NOTHING CHANGE AFTER RESET
v.1.0.2.80 reboot or WIFI drops or lost internet (AP mode) after 5 minutes....
Message 39 of 42
paillassou
Apprentice
I ask other users who are experiencing these problems to post here
Message 40 of 42
Jellev
Tutor
This will be my last netgear product, had the same sh*t with an R7000, now with the R7800, I'm sick of it!
Message 41 of 42
Iozone
Easy fix.  Don't use Netgear firmware.  Install DD-WRT and you'll be so much happier.  I certainly am.
Message 42 of 42
Top Contributors
Discussion stats
  • 41 replies
  • 8090 views
  • 11 kudos
  • 13 in conversation
Announcements
Orbi 770 Series
