Orbi WiFi 7 RBE973
Reply
Netgear R8000 - USB Storage and Samsung led tv
ChristianWis
Hello everyone
I have a router with a USB R8000 1TB disk and a LED TV Samsung F5500 model with the latest update. When I want to watch movies on the disc appear sometimes shared folders and other times not appear.
But the fundamental problem is that when I get to see a movie, shows 3 seconds and then restarts ... belies any movie.
I access via WIFI. And the TV is next to the router that is that I have excellent signal.
Anyone know how to fix?
I've always had problems with the R8000 and its official firmware and Samsung AllShare.
Please I'm desperate!
Thank you very much,
Christian
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: Netgear R8000 - USB Storage and Samsung led tv
Hi ChristianWis,
Are you still having issues with your router. Please provide an update.
Message 5 of 5
All Replies
JamesGL
Master
Hi ChristianWis,
1. Can you access the files or movies when using a computer?
2. What is the file format of your drive?
3. Can you try to use a different USB drive and see if the same problem?
4. What is the firmware version of the router?
Message 2 of 5
ChristianWis
Hi
Sorry by delay..
Hi ChristianWis,
Yes, I can to access using a computer
Format is NTFS
I cant, i have not another usb drive
the firmware is V1.0.3.4_1.1.2
Thanks in advance
Christian
Message 3 of 5
JamesGL
Master
Hi ChristianWis,
1. Is the Samsung TV connected via wired or wireless?
2. If it is wireless, is it on 2.4Ghz or 5Ghz?
Message 4 of 5
JamesGL
Master
Hi ChristianWis,
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2628 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
