- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear does not support their product
- Mark as New
- Bookmark
- Subscribe
- Permalink
After having bought several Routers from Netgear and many switches and other gear, I tried to get some technical support because there is a problem with WiFi bandwidth (wired bandwidth is fine), but they refused to help unless I paid $50. Unbelievable. Helllo TP-Link or Asus. Perhaps someone can suggest the best non-Netgear Router. Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Go for an ASUS, the AC86U is the current sweet spot until AX routers mature. Avoid TP-Link as they abandon their models pretty fast
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear does not support their product
Yes as Microchip stated go with Asus. There firmware support is light years better. Netgear just seems to have gave up and threw in the towel as far as firmware goes. Shame though they use great hardware. My place of employment has supplied me a Asus RT-AX58U and for a router no one is talking about this thing rocks with great speeds, coverage and no disconnects.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If going Asus make sure it is a model that RMerlin firmware supports. He adds features and fixes issues in the released firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@kenlaz wrote:
...they refused to help unless I paid $50.
This place is free.
Netgear also offers free support for 90 days.
Who did you call? If it was one of those sites found with a web search, then there is a high probability that it has nothing to do with Netgear.
Many of those listing are from third-party sites that pay to appear in the search engines. They then create sites that "borrow" the Netgear logo.
Those sites will also appear if you search for other makes of hardware. Using them can be dangerous.
Netgear farms out paid-for support to GearHead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I called and was talking to Netgear support. They are just aweful and a complete waste of time. Even refused to let me speak to a supervisor.
@michaelkenward wrote:
@kenlaz wrote:...they refused to help unless I paid $50.
This place is free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the helpful suggestion!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't say who you called.
Netgear doesn't hand out a phone number that you can call, which upsets many of the people who turn up here.
There is no phone support. You do it via the support portal:
Contact Us | Support | NETGEAR
Start here:
MyNETGEAR | Product Registration
Start a case and, with luck, they will contact you.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
