Orbi WiFi 7 RBE973
Reply
Netgear router - setting up priority for 5GHZ and 2.4GHZ
uinasbora
Follower
Hi there id want to ask how do I installation priority for a positive device to have it on the 5GhZ wifi as an alternative then the two.Four. I cant flip off the 2.4 currently so thats now not an choice.
Before a few sort of patch for the routerlogin.Internet it turned into effortlessly handled however now I cant seem to locate it at all and my desktop always connects to the 2.4 even as I set it up months ago to the five one.
Thank you earlier!
Message 1 of 3
microchip8
Master
Re: Netgear router - setting up priority for 5GHZ and 2.4GHZ
Not possible on router level. It's actually then client that picks up a band.
Message 2 of 3
Guru
what wireless card is it?
What OS is it installed in?
If its windows, you can set a preferred band for some devices
Message 3 of 3
Discussion stats
  • 2 replies
  • 469 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
