Orbi WiFi 7 RBE973
Reply
Netgear security is compromised on NETGEAR-5G-2
MikeT62
Tutor
R7900P — Nighthawk X6S AC3000 Tri Band WiFi Router
My router is password secured w/WPA2-PSK [AES], and I have Smart connect enabled. The problem is NETGEAR-5G-2 is advertised and connects without a password. However, NETGEAR70 is advertised but requires the wifi access password.
Even if I "Forget" NETGEAR-5G-2, it is still advertised and I can still connect without the wifi password.
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 8
Accepted Solutions
Guru
Re: Netgear security is compromised on NETGEAR-5G-2
have you tried a simple factory reset and re-install?
Or even re-installing the firmware?
Message 4 of 8
All Replies
Guru
which firmware are you on?
Message 2 of 8
MikeT62
Tutor
Firmware Version: V1.4.1.50_1.3.10
Message 3 of 8
Guru
Message 4 of 8
MikeT62
Tutor
Not yet. But I will as soon as kids finish school work. I'll reply back with results after complete. Thanks!
Message 5 of 8
MikeT62
Tutor
Reinstalling the firmware did not fix the problem. However, resetting the modem by pressing and holding the reset button in the back of the router with a paperclip for 15seconds corrected the problem. I guess when in doubt, reset first! 🙂
Thanks for the help!
Message 6 of 8
MikeT62
Tutor
Oops! I meant restting the router!
Message 7 of 8
Guru
Glad to hear you got it working properly
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2142 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
