Orbi WiFi 7 RBE973
Reply
Network no longer appears - Nighthawk R7960P
cmurdo2003
Follower
I have 3-6 devices connected to my wifi network and everything has been working until recently. Now our orginial network name doesn't appear, instead our devices are connecting to a generic 'netgear' wifi connection that is 'open'. The old network isn't available, or doesn't even get detected.
When I try to manually connect through my WIndows 10 'Network and Sharing Center' is also can't find the original, secure network. Strangely enough, when I connect directly with the ethernet cable, the original private network is used.
I've contacted Netgear support and the hardware is apparently working. I also contacted our interent provider, but they were unable to help and directed me back to Netgear.
Anybody have a similar issue? Thanks for any help.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
Guru
Re: Network no longer appears - Nighthawk R7960P
Which firmware version are you on?
What modem/gateway are you connected to?
maybe it was reset. The hardwired connection is just a name windows assigns, its not something the router controls.
have you tried factory resetting and reinstalling the router?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 257 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
