Orbi WiFi 7 RBE973
Reply
Network transfer speeds slow across Access Point
With_alligators
Follower
Hey folks,
Trying to solve a Network Transfer issue. Setup is as follows:
1 optimum modem in Bridge Mode,
Router is an R7000AC
          Which has wired connections to:
          -15' cat6 cable connecting to Computer A (10/100/1000 LAN)
          -50' cat6 cable connecting to an R6700AC in Access Point mode
                    -Wirelessly broadcasting to Computer B (802.11AC, 5GHz, 585/650Mbps)
Transferring large files from Computer B to Computer A max out at about 11MBps, which is more like 802.11b speeds. What settings can I check to try and get the most out my network? I will be regularly transferring large files. Computer B is located in a way where hardwiring is not possible. It is a very recent machine, with built-in WiFi 6 AX200 1600MHz capabilities (though that means nothing connected to the R6700). It should be capable of much faster transfer speeds, no?
Cheers!
Message 1 of 2
Guru
Re: Network transfer speeds slow across Access Point
11MB/s and not mb/s? Because 11MB/s is around 88-90mbps.
Which would be 10/100mbps speeds.
Did you check your wan/lan port statistics to see what they're connecting at?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
You can compare the r7000/r6700 to make sure its connecting at gigabit speeds
Message 2 of 2
Discussion stats
  • 1 reply
  • 885 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
