DMAP
Mar 13, 2023Follower
New Spectrum modem won’t talk to NETGEAR Nighthawk router
AC1750 Smart Wi-Fi Router
Model: R6700v3
Modem is live and Spectrum diagnosed from their end but unable to fix. I reset the router to factory settings but that didn’t work either.
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
