Orbi WiFi 7 RBE973
Reply
Night Hawk 6900v2 not getting my full speed
Lunacy1
I run through fiber 1 G and it will not get the full G it actually gets around 500 MB I tryed shutting off the qos or whatever it stayed the same am I missing something I can do because I will not downgrade the firmware
Message 1 of 3
Guru
Re: Night Hawk 6900v2 not getting my full speed
What is the CAT# lan cable in between the ONT and router? CAT6 is recommended for 1Gb speeds on the wire.
Are you speed testing with a wireless or wired device? Wired is preferred.
Try a different wired PC to compare results.
What speed testing app are you using? Ooklas installable speed test app is recommended.
Has a factory reset and setup from scratch been performed since last update and setup with out Armor, SPC or Traffic Meter enabled?
Message 2 of 3
Lunacy1
I had to step out I can tell you details when I get back but the isp tryed everything they could to help get it to 1 G. it only got a 600 MB option but on a the 5G it got the option for for 1500 but won't go over 600 but the router they usually provide to costumers was pulling the speed both ways but I'm a fan of the night Hawks i really don't want to switch
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 660 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
