Reply
Night Hawk R7000 - Change geographical location
Osunremi
My Night Hawk R7000 will not connect to the App so I need to change my geographical location manually. I am overseas but I don't want my employer to know my location. How do I change my location IP address to show Dallas Tx server instead of my ISP server?
Message 1 of 4
Guru
Re: Night Hawk R7000 - Change geographical location
You need a VPN hosted from the location you want it to show as.
Your work isn't basing it off your computer but off your ip address assigned by your ISP. (simplified version)
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
Osunremi
Currently have Nord VPN service. After further research, I believe I need to use "OpenVPN". There are some clear steps to do this but the initial step is to flash the router. Next step is to set the NordVPN addresses beneath DHCP settings (Network Server settings). I am not sure I am experienced enough to follow this.
https://techshielder.com/how-to-set-up-and-use-nordvpn-on-netgear-router
DD-WRT Firmware enables your router to work with OpenVPN. So, you have to install and flash your router with the DD-WRT Firmware first. (Yikes, I'm afraid to do this)
Message 3 of 4
Guru
If you want to use nordvpn, it installs a 3rd party firmware to your router.
You'd want to follow their guides for install/usage and not the official netgear forum
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 353 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
