- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk R7000 wireless connection issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have had a NightHawk router running in my house for at least 4 months. Yesterday it randomly stopped working. We can no longer connect wirelessly to the router.
The front panel shows the power and internet coming in working or showing the lights on. The 2.4 & the 5 GHz lights are not on.
The only thing I've tried is to disconnect & then reconnect...this did not solve the issue.
Any help would be appreciated.
thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try pushing the physical Wi-Fi button for a couple of seconds. This will toggle the radios on/off.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk R7000 wireless connection issues
Looks like you'll need to do a factory reset. If that doesn't work, something might be fried inside the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks TheEther....this did the trick.
