- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC1750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have owned for about a year. Most status lights are currently blue. recently purchased a cat 6 ethernet cable to attach to laptop and the status light is RED. Why the diffence between blue and red status lights? Will the difference cause harm to my router?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
That router doesn't have any red led's built into the ethernet leds. . Its only amber/white.
check in your network settings to see if its connected at a 100mbps link rate. If so, its amber (but maybe looks red).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AC1750
which status light?
the manual tells you which each led is and indicates.
you can find the manual here: https://www.netgear.com/support/product/r6700
- Mark as New
- Bookmark
- Subscribe
- Permalink
was asked as a reply "which status light". The status lights corresponding to ethernet port 2, 3, 4, (tried all three) all light up red whenever I plug in my laptop It was even suggested that I download the manual and it would explain it to me. Nothing in there about red lights that I have found.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't suppose that color is amber?
directly from the manual:
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100
Mbps or 10 Mbps Ethernet connections.
• Solid white. A powered-on device is connected to the Ethernet port.
• Blinking white. The port is sending or receiving traffic.
• Off. No device is connected to this Ethernet port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm sure that the light is NOT amber, it is as red as as an apple. I have cable modem connected to the ethernet port, desktop computer connected to ethernet port #1 (both lights are blue/clear. Laptop is connected to ethernet port #2 and light is RED. We need to have the router connected to modem and desktop so that everyone else in the house can connect their devices and use the wireless network however this particular laptop needs an ethernet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so every device that connects to the router works properly except for the laptop?
That's what I'm understanding from your prior statements.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the laptop that is connected to the router does seem to work properly and without any problems, I'm puzzled by the red light when all other lights are blue/clear. Could if be possible that the ethernet cables are classifed as cat 6? The other two ethernet cables are cat 5.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
