Orbi WiFi 7 RBE973
Reply
Nighthawk AC1900 Antenna type: Dualband?
PD0OYH
Hello. I want to use high gain antennas on my R7000 AC1900. What type of antenna is the default antenna on all 3 connections? Is it single band or dual band? Manual and websites have no info about this.
Message 1 of 6
Accepted Solutions
PD0OYH
Re: Nighthawk AC1900 Antenna type: Dualband?
Message 4 of 6
All Replies
netwrks
Master
Message 2 of 6
PD0OYH
Thanks for the fast reply, i still can not find the information ... its not there as far as i understand English.
Message 3 of 6
PD0OYH
Message 4 of 6
rpoffen
Virtuoso
If you get these (or something similar) please post back about how successful you are with them.
Message 5 of 6
VE6CGX
Master
Hi-gain antenna means it is sacrificing omni-directional radiation pattern to increase gain to a certain
direction.  And also it affects radiation angle(X & Y axis). As long as you understand this. As well antenna
impedance matching is very important. Mismatched antenna can result in loss of TX power or bad signal.
Trustworthy antenna will come with decent tech spec. sheet.
Message 6 of 6
Discussion stats
  • 5 replies
  • 13364 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
