Orbi WiFi 7 RBE973
Reply
Nighthawk AC2300 firmware update fails
Tall-Eric
Tutor
It current has firmware version 1.3.1.26 and Nighthawk mobile app informs me an update to 1.3.1.64_10.1.36 is avaialble. I ask it to install, the app says it completes and reboots, but then I get the same prompt again.
What do I need to do to get the firmware update to take?
thanks in advance
Message 1 of 4
Accepted Solutions
Guru
Re: Nighthawk AC2300 firmware update fails
I would try manually doing the update. download the update, extract it, and then follow the manual install instructions from the manual.
I also recommend doing the update over a hardwired connection for the best results.
Ac2300 isn't a speed but based upon the firmware you posted, you probably have the R7000P?
here's where you'd get the firmware and manual.
https://www.netgear.com/support/product/R7000P.aspx
Message 2 of 4
All Replies
Guru
Message 2 of 4
Tall-Eric
Tutor
thanks, will try this weekend and report back
Message 3 of 4
Tall-Eric
Tutor
thank you, that worked! Much appriciated
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1414 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
