emciver79's avatar
emciver79
Follower
Oct 18, 2022
Nighthawk AC4000 3x3 Tri-band WiFi Router (R8000P) Firmware won't update
Looking for some help here.  My firmware hasn't been auto-updating even though I have that setup in my settings.  When I click the firmware update button on the admin page, continue to get "cannot connect to netgear server" error.  I went to website, downloaded latest firmware file, then went into admin and manually uploaded the file.  The process seemed to go through, it reset my router, but the firmware doesn't show updated.
Anyone have any other tips for me to get this firmware to update?
I am on firmware version: V1.4.1.50_1.3.10
New firmware version file I downloaded was:  1.4.4.94_1.3.56
Thank you!
    Thank you!
    Experienced users recommend turning off auto update.  Either it doesn't work or creates problems along the way.
    This is a good reference for manually updating firmware:
    https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
    The most important step is step one where it says to connect your computer to your router via an Ethernet cable.
