DJP72
Dec 29, 2022Follower
Nighthawk R6700v3 speed too slow
I just upgraded my Internet to a fiber optics company today at 500mb download/upload speeds. Everything is working fine, except my Nighthawk R6700v3 router will not go any faster than about 180mb or so, both download and upload. The technician and I tried several things: rebooting the router, updating the firmware, etc. No luck. We plugged directly into the modem and the speed was as advertised, so it's clearly a router issue. Does anyone have any suggestions, other than buying a new router? Although the router is 2 or 3 years old, the technician didn't think it should be having these issues. Thanks for any ideas!
1 Reply
Did you try factory resetting and testing with the default configuration? (make sure not to enable access controls, parental controls, traffic monitoring, or qos during the reinstall)
What modem/gateway did you get from the fibre company?
