Reply
Nighthawk R6700v3 support fiber ?
icadar
Follower
Nighthawk R6700v3
Firmware Version
V1.0.4.128_10.0.10
Windows 10 , ROKU  Youtube TV  ,  iOS phones
Just moved and have Spectrum Fiber installed ,, using Spectrum Fiber modem and my Nighthawk router...
Seems that the Nighthawk router is not compatible with Fiber,,,
I have tried all the typical tasks without any luck,,,,
Experiencing  Slow internet connect to urls via iphones ,,, elongated connecting from Smart TV/Roku ,,   Netflix/Youtube TV,,,,
Does this router support fiber ?  Do i need to have Spectrum install their rental
router....  Is this some tweek that needs to be done ???
Thanks in advance
Message 1 of 3
Guru
Re: Nighthawk R6700v3 support fiber ?
What fibre gateway did they install? (model)
It should work fine on fibre so long as your connection info is correct
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Did that include a rest for your router?
You need it to forget its settings from your previous network.
As @plemans says, there is no reason why a router shouldn't work with any Internet service, With fibre it is often just a case of plugging the WAN port from the router into the LAN port on your fibre connection.
It sounds like the thing is working. So, back to that reset.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 482 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
