Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 Won't connect to mij modem
capes
Follower
All day long i have a big problem with my R7000. For a few months he worked perfectly. But today was a problem with my modem. When that was solved the R7000 has no connection anymore with internet and the light still blinking amber. When i put the wired cable direct from the modem in my comp then it works perfectly! During the problems this morning i have reset the router and i think there is the problem began...
Genius sees the router but i can't do anything to change it.
Is there anybody who can help me???
Message 1 of 2
Accepted Solutions
Babylon5
NETGEAR Employee Retired
Re: Nighthawk R7000 Won't connect to mij modem
What kind of modem do you have e.g. cable or DSL, and what is the manufacturer and model number?
If you have a cable modem then it’s normally necessary to power cycle the modem when changing the device that is connected to it.
Message 2 of 2
All Replies
Babylon5
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3295 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
