- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 keeps restarting after firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I've tried to upgrade the firmware of my router manually (using the html GUI by uploading the .chk file) to the lateset version (v1.0.9.42_10.2.44) but unfortunately this time it seems to broke the Router.
The Router restarted itself after the upgrade but now it keep restarting...
I've tried to reinstall the firmware using the tftp method but it times out. The ping to the router IP address (192.168.1.1) is not consistent and thereforce i assume that the Router keeps restarting itself (as i can in the LEDs too).
It there anything else that i can try besides the tftp method?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. The TFTP Reflash (method) for recovery is the recommend procedure to recover from this condition.
Success depends largely on proper configuration and most of all timing . Don't be discouraged. It can take 3-4 tries before you get it. The "window of opportunity" to catch the router listening is brief. Keep trying, I'm sure you'll get it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
