Palmcricket's avatar
Palmcricket
Nighthawk R7000 not connecting to internet
We recently had a storm come through and our electricity went off for a split second, now my router is not able to connect to our internet.  The wifi shows up on our devices but is not able to load anything.  We live in the country so we have satellite internet.  I have unplugged both power sources (to the router and to the antenna) and i have reset the router numerous times, each time it has rebooted, and i go into the genie it can't connect to the internet.  Any help or suggestions would be great.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Palmcricket,
    Do you have modem or is the router directly connected to the wall? If you have modem, connect your computer directly to the modem and check the connection. Same thing if you don't have a modem, connect a computer directly to your wall patch and check if can go online. If no connection, you may need to check your ISP.
  • It was my isp they were having problems thank you for the reply.
    • JamesGL's avatar
      JamesGL
      Hi Palmcricket,
      Thank you for the update.
