- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7450 Lost local network after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
After updating my router's firmware to V1.2.0.92_1.0.1, I have lost all local network connections.
I have 4 Windows 10Pro PC's connected, they all still have internet access, but are not able to see each other on the local network.
I have a USB3 HDD connected to the router and the Media Server still works for BlueRay/DVD players, but I cannot connect to the Readyshare drive with any PC to access the files, I have to physically remove the drive from the router and connect it to a PC to access the files.
In the PCs I have "SMB 1.0/CIFS Client" turned on, but turning it off doesn't help.
I have factory reset the router, it did not help.
Everything worked fine before the firmware update.
Anything else I should try?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@buzbard wrote:
Yes network is still set to private.
Tried the network troubleshooter in Windows?
It used to be a joke but has been getting better/
Have you tried typing the device addresses into Windows Explorer?
Devices have a habit of going AWOL. They suddenly sprint into view if I do that. One reason why I keep shortcuts to the rest of the network, PCs and NAS stuff.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40VAll Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7450 Lost local network after firmware update
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you check on the windows pc's to see if they'd changed their network connections from private to public?
It could be it thought the router was a new network after the firmware upgrade and when set to public, isn't able to see the shared drives/computers.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just tried all that again with no luck.
Disconnected power to both modem and router, and waited 5 minutes.
I powered up the modem and waited for the internet connection (about 3 minutes), then I connected power to the router and powered it up.
I then waited another 5 minutes before checking network connections.
When I open Windows Explorer and click Network, I can see the PC that I'm currently on plus the R7450 (Gateway), modem "ZyXEL APS" and printer (Brother HL-L2360D series) and that's all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
Typing the device address into explorer, sheesh, why didn't I think of that?
Used to do it all the time in Windows 2000, forgot all about it.
\\READYSHARE\USB_Storage
Thanks!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!!
I suppose it is progress that you haven't had to use that one lately.
Windows networking has always caused problems here. NAS things go AWOL all the time here.
