Orbi WiFi 7 RBE973
Reply
Nighthawk R8000
Jsimo2915
Nighthawk R8000
My router is losing internet connection and has to be reset almost every 12 hours. Have had the internet provider come to the house and go over everything on their end. Firmware is updated. What can I do to fix this issue.
Message 1 of 4
Guru
Re: Nighthawk R8000
what modem do you have?
What actual firmware is on it? "the latest" isn't always the greatest.
Do you mean reboot and not reset? Did you try a factory reset?
Message 2 of 4
Jsimo2915
Re: Nighthawk R8000
Reboot. It has had the same problem since buying and installing around a year ago. It has the latest firmware but has had the same problem with all of them.
Message 3 of 4
Guru
Re: Nighthawk R8000
You've tried "all" the firmwares?
And did you do a factory reset during any of those changes?
The Armor upgrade changed firmware enough that a reset is warranted
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 514 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
