Orbi WiFi 7 RBE973
Reply
Nighthawk R8000P blocking valid network traffic, "DoS Attack"
mnissov
Follower
I have a netgear nighthawk R8000P router, firmware V1.4.4.94_1.3.56, which is consistently blocking NTP synchronization, calling it a Fraggle Attack.
Even basic things like pinging google get blocked. For example, I write
ping google.com
 which returns with "Request timed out" and in the router log we see:
[DoS attack: Fraggle Attack] from source 129.241.187.29,port 17500 Thursday, Mar 23,2023 10:34:16
at what seems to be the same time. Note, although pinging google times out, actually going to the website using my browser works fine.
Furthermore, trying to synchronize with time.nist.gov returns with "This operation returned because the timeout period expired" with the log showing
[DoS attack: Fraggle Attack] from source 129.241.187.29,port 17500 Thursday, Mar 23,2023 10:38:17
again at what seems to be the right time.
If I disconnect the WAN from the router and plug directly into my computer, this has no problems synchronizing to the same NTP server.
Note, my computer has all windows firewalls disabled and the router has all security features disabled (as far as I'm aware).
Message 1 of 2
Guru
Re: Nighthawk R8000P blocking valid network traffic, "DoS Attack"
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this happen with other PCs?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 887 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
