Orbi WiFi 7 RBE973
Reply
Nighthawk R8500 wifi local network bandwidth / slow
LEFBE
Hello community,
Below my network configuration
  • All physical devices like desktop, Nvidia shield are connected with RJ45 cat6 10 Gigabits
  • Nighthawk R8500 provide only 5GHz wifi signal for Macs, tablet and phone and no have internet connection (provide only local service)
  • 2 switch ref: D-Link - DGS-105
Internet => Box (provide DHCP) => R8500 (provide wifi) => Devices
Problem:
Since I've upgraded to the newest firmware V1.0.2.86_1.0.75 I encounter some wifi problems.
Based on wifi reference, my network can provide 450 Mbps (56.25 MB/s)
Local file transfert
Laptop : MacBook Pro Retina
FIle size : 1 Gb
MBP to NAS server
Transfer 1Gb over the network cannot exceed 18 Mo/s
Before upgrading bandwidth was around 30 Mo/s
Wifi / router stability
Since this upgrade I need to restart my router every week
Since this upgrade some devices are randomly detected.
Please note:
Recently, I have to make a reset factory because the router was not responding.
I've apply my router configuration saved to restore it.
Someone encounter the same problem?
Do you have any advice?
Add screen
Upload 6bG over the network MBP to NAS
Download 2;3GB over the network NAS to MBP Pro
Thanks by advance,
LEFBE
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
Accepted Solutions
LEFBE
Re : Nighthawk R8500 wifi local network bandwidth / slow
Hello Community,
I think I have found the solution.
Switch from chanell 48 to 60 (DFS)
Result are here now :
  • Before: 19 MB/s
  • After: 35,8 MB/s
LEFBE
Message 2 of 2
All Replies
LEFBE
Hello Community,
  • Before: 19 MB/s
  • After: 35,8 MB/s
LEFBE
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1808 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
