Orbi WiFi 7 RBE973
Reply
Nighthawk Router Extra Connection Appearing (sometimes)
riche22
Tutor
Typically my Nighthawk router works amazing, but sometimes an additional wifi channel is opening up. My typically "Netgear29" will sometimes also be accompanied with a "Netgear29-5G2". This new network also runs at substantially higher speeds usually, and doesn't recquire a password. They are both 5G. I know it has the tri-band, but I have it set up to automatically distribute the devices. Why would my second 5g band suddenly be popping in and out of existence like that? And... Not automatically just connecting stuff to it?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Nighthawk Router Extra Connection Appearing (sometimes)
Did this just start happening?
How long has it been going on?
there is a security hotfix you can install 1.4.1.82.
Might help/might not.
I'd recommend installing the hotfix, then doing a factory reset/reinstall.
Message 4 of 6
All Replies
Guru
What firmware version are you on?
Are you using smart connect?
Message 2 of 6
riche22
Tutor
V1.4.1.68_1.3.28
I am using smart connect.
Message 3 of 6
Guru
Message 4 of 6
riche22
Tutor
It has been like this for a few weeks, but I have not had time to look into it until now. I also noticed that if I login to the router through my computer, the "5G-2" network is showing a yellow triangle with a ! as opposed to a green one with a check. I'll update.
Message 5 of 6
Guru
Let me know how it goes!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 764 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
