- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4 AC2350 Smart WiFi Router Model R7500
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've installed a new Ring Security System and connected the base station to my router with the supplied ethernet cable. In doing so, I get an orange blinking led light on that ethernet port. I've checked the connection through Ring tech service, and they can see that it is active and working properly, and suggested I check with the router manufacturer.
I've moved the wire to a different port, tried the connection with a different ethernet wire. I also checked for any router updates it's up to date. I then pushed the reset button and reset the router, and still it comes back with an orange blinking light.
Since everything seems to be working properly, should I accept the light as normal? Any other suggestions that I may try?
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4 AC2350 Smart WiFi Router Model R7500
Thank you for this confirmation. Good to know all is well.
