Orbi WiFi 7 RBE973
Reply
Nighthawk X6 AC3200 R8000 router with sonos
kcordan1
Follower
I have my sonos set to my router.  How do I keep other people from getting on my sonos and changing music.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 3
Guru
Re: Nighthawk X6 AC3200 R8000 router with sonos
the router doesn't control the sonos.
You'd be better to ask this on the sonos website.
Message 2 of 3
Guru
If its ONLY  your network and people are getting on it, change the ssid/password of the router so others can't access it. Then they couldn't use the sonos. Otherwise, I'd check on the sonos support/forum.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 814 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
