Orbi WiFi 7 RBE973
Reply
Nighthawk X6 R8000 - cpu problem
ChristianWis
Hello friends, I have a Nighthawk X6 R8000, excellent router. But I have a problem that I'm noticing recently. I have 28 devices connected and the router in standby mode has a consumption of cpu1:34% and cpu2:98%, this causes me to run out of network at times and need to restart the router. What could be happening? Thanks Christianfotorouter.jpg
Message 1 of 6
Accepted Solutions
Guru
Re: Nighthawk X6 R8000 - cpu problem
Now do same thing with the router disconnected from the ISP modem or ONT. Observe CPU usage.
What is the Brand and model# of the Internet Service Providers modem or Fiber ONT the NG router is connected too?
Try a factory reset and setup from scratch..A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Try this with just one wired PC connected. When the setup wizard completes, check the CPU usage. Don't connect anything else just yet. Set a different SSID name to prevent wireless devices from connecting.
Also there is newer version of FW as well:
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/New-R8000-Firmware-Version-1-0-4-84-Re...
Message 4 of 6
All Replies
Guru
What happens when you disconnect all from the router accept for 1 wired PC? CPU usage still high?
What all you have connected at one time?
Is Armor, Circle or Traffic meter enabled?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Message 2 of 6
ChristianWis
What happens when you unplug everything from the router for 1 wired PC? CPU usage still high?
1 pc only,
CPU load
CPU1: 17.45% CPU2: 19.15%
Everything you have connected at once?
And it is
Is the Armor, Circle or Traffic meter enabled?
nope
What firmware version is currently loaded?
firmware version
V1.0.4.76_10.1.82
What is the Mfr and model number of the ISP modem/ONT that the NG router is also connected to?
I don't know what is the "Mfr and model number of the ISP modem/ONT"
Make sure to use a good quality LAN cable between the modem and the router. CAT6 is recommended.
I have cat 8, but most devices connect via wifi to the 2.4 ghz network
Has it been turned off for 1 minute then back on with ISP modem and router since last update?
Yes..
Be sure to reboot your network in this sequence:
Turn off and unplug the modem.
Turn off the router and computers.
Plug in and turn on the modem. Wait 2 minutes for it to connect.
Power on the router and wait 2 minutes for it to connect.
Turn on the computers and the rest of the network.
yes i did that
Thanks
Message 3 of 6
Guru
Message 4 of 6
ChristianWis
ok.. i was able to solve the problem.
The problem was not the router, but a PC with ubuntu and 5 docker images including transmission soft...
all right!
Thanks for the help
Message 5 of 6
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Its recommended to install a USB laptop cooler under the router for 24/4 cooling. Helps keep the router cool and helps avoid heat damage to the electronics.
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2662 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
