Orbi WiFi 7 RBE973
Reply
Nighthawk X6 firmware upgrade issues
LupaLuna
Follower
  • I logged into my router online. I've trIed to do the firmware upgrade and it went through the process. It never rebooted the router. How do I figure out why this is happening and how do I get this firmware upgrade to go through?
Message 1 of 2
Guru
Re: Nighthawk X6 firmware upgrade issues
What actual model router do you have?
What firmware are you trying to install?
What version of firmware are you on currently?
Did you try installing it manually? or using the automatic installer?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 215 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
