- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X6 r8000 slow wired connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The xbox is a little harder (since you figured out the roku).
I've seen numerous posts on here about xbox's not hitting full speed when ran through a router but will when ran directly through the modem. Not sure if its how microsoft has their backend setup as even with the xbox entered into the routers DMZ (automatically forwards all data in basic terms), you still get the lower speeds. But 200mbps should still do everything you need. Streaming 4k only takes 25-40mbps and gaming itself doesn't use much data. It just slows you down a little for downloading games but even that isn't much as its still 200mbps.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X6 r8000 slow wired connections
After changes like you described, a complete power down of your network is in order. The sequence, configuration, and timing of the restart is critical for success.
Power down (pull the power cord) on your modem. Disconnect the coax and the Ethernet cable to the router. Let these items sit while you tend to the router
If you have any USB items connected to the router, dismount and disconnect them. Power down and remove the power cord.
Back to the modem, connect the coax only and the power cord. Give the modem ample time to boot and connect to your ISP. Connect the Ethernet cable to the router and give it ample time to boo.
Connect a computer via Ethernet cable. Install the native OS application from Ookla and test your connection capacity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If @Kitsap advise doesn't work, then I'd try the factory reset. The qos/access control/traffic monitoring/parental controls features might be disabled but if they were ever enabled, I've seen them not turn CTF back on when they got disabled. In those cases, I usually just start with a factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear you now have the proper download capacity to your laptop computer.
Let the router run for a few hours, do a power cord removal boot. Then check your Xbox and Roku.
Beyond that the usual trouble shooting steps including cables. Not familiar with Xbox, but there may be updated firmware for your Roku.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
