Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X6S AC4000 best t568a or t568b?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-03-03
05:54 AM
2021-03-03
05:54 AM
What is Nighthawk X6S best wired for a t568a or t568b?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-03-03
06:10 AM
2021-03-03
06:10 AM
Re: Nighthawk X6S AC4000 best t568a or t568b?
It really doesn't matter.
They just wiring standards. Both ends of the cable are wired using the same standard. Even if you mix them up making your own cable, it creates a crossover cable which is what you used to use for directly connecting 2 pc's together without a router/switch.
Message 2 of 2
Announcements
