Orbi WiFi 7 RBE973
Reply
Nighthawk X6S R7900P authentication email incorrect.
ghoulie27
Initiate
I have a Nighthawk X6S R7900P and the authentication email displays the wrong email. My free support has ended and I cannot find anywhere to change the email to the correct email.
Steve
Message 1 of 5
Accepted Solutions
ghoulie27
Initiate
Re: Nighthawk X6S R7900P authentication email incorrect.
Thank you. I chatted support and while chatting I did the following: In the Nighthawk app, I disabled two-step authentication, logged out, logged back in and then enabled two-step authentication. I logged out and then back in and it did show the correct email in the two-step authentication process. Also, support refreshed my email on their end.
Message 4 of 5
All Replies
Guru
Try logging into your NG profile account and change email addressing here?
https://accounts.netgear.com
https://my.netgear.com
If not, you'll need to contact NG support and ask them to help you with this.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 5
Email for what?
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 3 of 5
ghoulie27
Initiate
Message 4 of 5
Guru
Thanks for the process. Glad you got it working.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 772 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
