Orbi WiFi 7 RBE973
Reply
Nighthawk X8 R8500 Rattle - How to Open Box
Dr_Dan
My router is working fine, but when I picked it up and moved it I noticed a rattle. I think something small may have fallen into the box. I found 2  obvious hex screws on the bottom, but I'm sure I must be something else to open the box. I'd appreciate any help.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 5
Accepted Solutions
doraemon
Prodigy
Re: Nighthawk X8 R8500 Rattle - How to Open Box
There are more screws on the feet.
Remove the rubber feet in each corner and you'll see more screws.
gimme dorayaki 😄
Message 4 of 5
All Replies
TheEther
Guru
You can find videos on Youtube. Search for "R8500 disassembly".
Message 2 of 5
Dr_Dan
I already looked there. I found a video for the x6, but it's a different box and doesn't apply.
Message 3 of 5
doraemon
Prodigy
gimme dorayaki 😄
Message 4 of 5
Dr_Dan
Thanks, that did the trick! It turned out to be a little piece of black plastic that had broken off something.
For anyone trying to accomplish this, you can pry off the rubber feet with a screwdriver. If you're careful, you can just pry up half and bend it back enough to remove the screw without taking the pad off completely, making it a little easier to just stick back on.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4590 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
