- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk rooters and https admin GUI
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Why we still don't have any option to access GUI management through https and disable http, either for remote management and for local management
Using http any being impossible to disable it is a big security issue, even through LAN
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, I meant page 160. The example shows: http://134.177.0.123:8080 when it should be https://137.170.0.123:8080.
On page 159, the picture shows Remote Management Address: https://0.0.0.0:8443.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk rooters and https admin GUI
- Mark as New
- Bookmark
- Subscribe
- Permalink
In manuals and options, i only see http for remote, with option to change port, which is kidding as of security
Even locally, a bad site can sniff the pass by redirecting a simple malicious script to the http admin gui. If you saved pass, it can sniff it
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see nothing relevant P180 !
Remote management is in P159-160
It definately shows using http through a custom port, no SSL through 443 port
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, you are right, I missed in GUI Setup the https and I trusted the web and manual text
Can you confirm that access through http is actually disabled remotely ? That is if you try through http it will not be allowed?
I will rise a features to add about https only access through LAN
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm running 3rd party firmware so I can't personally confirm that http is disabled. It would be simple enough for you to test via a smart phone connected via cellular.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
