Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk x6 R7900 5ghz isn’t discoverable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-11-04
01:05 PM
2020-11-04
01:05 PM
Noticed that my 2.4G and second 5G band were showing up on all my devices, but not the first 5G band. I’ve updated the firmware, I’ve disabled the broadcast then enabled it, and I’ve also reset it back to factory settings. None of which have worked. The bands I have still, work great but I can’t figure out why the 1st 5G band SSID isn’t discoverable. The lights on the router are all fine with no bad indication, and this is the first time this issue has happened in the 2 years I’ve owned this router.
I’m welcoming to any solutions.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-11-04
01:09 PM
2020-11-04
01:09 PM
Re: Nighthawk x6 R7900 5ghz isn’t discoverable
Smart COnnect enabled? Read this -> https://kb.netgear.com/25346/What-is-Smart-Connect-and-how-do-I-enable-or-disable-it-on-my-Nighthawk...
"For Smart Connect to work, both 5 GHz radio bands must use the same WiFi network name (SSID) and network key (password). That means that when you connect to the router with WiFi, you see only one 5 GHz SSID that connects to both 5 GHz radio bands. If you enable Smart Connect and the SSID and passwords for both 5 GHz radio bands do not match, the WiFi settings for 5 GHz radio 1 overwrite the WiFi settings for the 5 GHz radio 2."
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-11-04
01:42 PM
2020-11-04
01:42 PM
Smart Connect is not enabled. I tried enabling it after reading your comment to see the effect, but it combined the bands into 1 band.
Thanks for making sure I didn’t have it enabled. Still up for more suggestions.
Message 3 of 3
Announcements
