Orbi WiFi 7 RBE973
Reply
NighthawkNighthawk X6 R8000 firmware V1.0.4.84_10.1.84
aiaf1
Follower
Just let router update to latest firmware. V1.0.4.84_10.1.84
restart etc as per normal.
now the second 5GHz-2 is no longer available.
All setting correct, but no longer broadcasts.
Worked before the update. Firmware bug.
Have tried all the frequency to no change in outcome.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Guru
Re: NighthawkNighthawk X6 R8000 firmware V1.0.4.84_10.1.84
Did you try a factory reset?
Does it show as disabled in the gui browser?
Are you using smart connect?
Message 2 of 2
Discussion stats
  • 1 reply
  • 994 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
