Orbi WiFi 7 RBE973
Reply
No Remote Management
BigDingus
I've looked everywhere but can't find my remote management.
Definitley not showing in advanced.
Anyone know why itisn't showing?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Re: No Remote Management
@BigDingus wrote:
Web Services management only offers a tick box for Always Use HTTPS to Access Router
My Orbi is RBR50 (From memory)
It also shows Remote Management on my Nighthawk router.
You could also see if you can enable that in the Orbi App and a local wifi connection.
@BigDingus wrote:
Sorry if I posted in the wrong forum.
Not a problem, but as you can a see Orbi may not be the same as Nighthawk.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 4 of 4
All Replies
Maybe the manual is out of date. What about Web Services Management?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
Orbi devices are very different from Nighthawk routers in things like Anywhere Access and Remote Management.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 4
BigDingus
I think I'll just use it as it. Thanks for your input.
Message 3 of 4
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 995 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
