Orbi WiFi 7 RBE973
Reply
No antennas for Nighthawk AC1900 Model R7000
chucker8
Follower
Hi,
I received a Nighthawk AC1900 Model R7000 router, but I didn't receive the antennas.
Will the wifi on the router still work?
thanks
Message 1 of 2
Guru
Re: No antennas for Nighthawk AC1900 Model R7000
Barely, you can connect any antenna that has the screw on connections and will work. I had to do the same to mine as some how I lost the antennas so I grab some from a different router. Works.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 674 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
