- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No power light?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No power light?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No power light?
If its only the power light that is red, it indicates either a failed bootup or corrupt firmware issue.
I'd try the factory reset and see if it helps.
If it doesn't then you might need more drastic measures.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
