Reply
No wifi on the third floor
Mnmsprague1779
I just purchased a nighthawk r7000. My modem is currently located in the basement and the router is there too. I cannot bring it up to the main floor without re-wiring. What are my options to get wifi on the third floor? I don't even get a week signal up there.
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: No wifi on the third floor
You could try power line adapters. You'll never have decent thoughput.
Message 3 of 4
All Replies
VE6CGX
Master
Your router should sitting on the third floor or one floor down from there. If you can't relocate router, seek another means with
AP or repeater.
Message 2 of 4
Retired_Member
Not applicable
Message 3 of 4
Mnmsprague1779
Thank you!!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2444 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
