Reply
PS3 won't connect through WiFi
theherm
I've managed to connect my new R7000 once to my PS3 using WiFi. After that the PS3 won't connect to the router. Using a cable works fine, but I can't seem to be able to connect wireless. I've tried turning WiFi security off, but it didn't work.
The R7000 is connect directly on the ISP's modem, which is switched to brigde mode.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 7
Accepted Solutions
theherm
Re: PS3 won't connect through WiFi
I've found the solution. I did put my ISP's modem/router in bridge mode, but appently Wifi was still on. Since I configured my Netgear router with the same SSID as the ISP's router, it probably was causing clashes or something. Anyway, after turing the Wifi signal off on the ISP's router, the PS3 is connecting flawlessly!
Message 6 of 7
All Replies
Can anything connect to the wifi?
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 7
theherm
Yes, tablets, phones, laptops and other devices work fine on 2.4 and 5 Ghz.
Error shown on the PS3: time out while retriving IP address
Message 3 of 7
This probably means that your problem is on the PS3. The router is doing its thing, throwing out wifi that other kit can handle.
Can you tell it to forget old wifi connections and set up the link afresh?
Or consult experts in PS3.
Message 4 of 7
Guru
If you tried the PS3 with out any security on the router, there maybe a problem with the PS3 or maybe not incompatible with newer generation wifi routers.
You can do this, install a wireless bridge with LAN ports in back. Routers or there are actual wireless bridge devices that you can use. Set up this wireless bridge with the PS3 LAN wire connected to the back of the wireless bridge. The bridge will connect to the NG router wirelessly.
Direct Wired LAN cable is best for game consoles however.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Routerand RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
Message 5 of 7
theherm
Message 6 of 7
Guru
Enjoy. Smiley Wink
Message 7 of 7
Discussion stats
  • 6 replies
  • 8435 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
