Orbi WiFi 7 RBE973
Reply
PS5 Netgear Nighthawk R7000 Slow Download Speeds
jayswat
Follower
Unable to get full capable download speeds to my PS5, capped around 200Mbps download.
Setup
  • 1Gbps Fiber service
  • Nighthawk R7000 Router
  • PS5 is hardwired straight to the router with Cat5e cables.
  • PS5 assigned static IP
Router Settings
  • Factory reset and updated to latest firmware
  • All extra functions have been turned off or disabled
    • QoS
    • Traffic Metering
    • Etc...
  • Port forwarding for PS5 static IP
    • 80,443,1935,3478-3480
I have tested multiple Cat5 cables.
If I unplug the cable from the PS5 and plug it into my laptop, I'm able to get download speeds over 900Mbps.
If I plug the PS5 straight to the modem, I get near max speeds.
There appears to be an issue within the R7000 that is preventing the PS5 from attaining anything over 200. I have researched as much as possible and this seems to be a common issue with the R7000 and PS5 but have not found anyone who has solved it.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: PS5 Netgear Nighthawk R7000 Slow Download Speeds
What FW version are you using on the router?
Does a ethernet connected PC and Ooklas installable speed test app result is seeing same speeds results?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1024 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
