Orbi WiFi 7 RBE973
Reply
Plex not showing movie images R9000 x10 or scanning media files for more than one library
Salakos
Tutor
I saw that someone previously had a similar, if not the same issue. Their write-up is as follows: "
Just setting up Plex on my R9000, connected USB 3 thumbdrive (32GB), and usin g my NAS as storage for my movies. But no image/poster is beeing downloaded, all movies are just grey boxes. Info and so on working fine, but only images not working.
Is there a solution for this, working fine when I used my NAS as mediaplayer."
In my issue, I have a server set up on my laptop that interfaces with my NAS just fine. However, my laptop is not ideal for streaming movies for several reasons (one being that my PS4 Pro and the router both use 5G and my laptop does not. But I digress) Anyway, I got the new firmware update that allows you to set up a Plex server on the router that uses an NAS. I purchased a 128G Samsung USB3.0 thumb drive, plugged it into the router and opened the Plex server. I added multiple directories into multiple libraries, but the server will only detect movies in one library. Also, in that library, media is matched and the info is working, but the artwork is not present (nor can I add artwork with the upload custom artwork function.)
This issue is marked solved on a previous thread, with the solution being listed as: "Solution is formatting to "OS X Extended (Journaled)", not working with FAT32 or EXFAT."
I have no idea what that means. Reformat the NAS? (I definitely won't be deleting 12tb of media for a reformat.) Or is it talking about reformatting the USB? If so, how would I go about that? I am very confused and frustrated with this whole process.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 7
Accepted Solutions
Guru
Re: Plex not showing movie images R9000 x10 or scanning media files for more than one library
NTFS is more universal. Let us know how it goes. Just use a Windows PC and format for NTFS using defaults.
Message 4 of 7
All Replies
Guru
OS Journaled is a Apple OSX formatting. Doesn't work in WIndows. I presume they were operating in OSX for there problem.
Have you formatted NTFS?
Message 2 of 7
Salakos
Tutor
I have not, yet. I will begin to reformat the USB to NTFS, if you think that will help.
Message 3 of 7
Guru
Message 4 of 7
William10a
Master
Thats the problem with Apple with a different format for the harddrive then Windows and Luix with its own too bad there is not standard that would the readyshear work across a network with many different make of computers and devices that would help a lot.
Message 5 of 7
Salakos
Tutor
Well, so far so good! The reformatting to NTFS was very helpful. I left the program running overnight to scan libraries and it seems to be fixed. The library scan is not going nearly as fast as I would hope, but what are you going to do when you have 12 tb of video files to scan and match? Thank you!
Message 6 of 7
Guru
Ya 12Tb is vary large to scan. Glad NTFS worked out.
Enjoy. Smiley Wink
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 6072 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
