- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders
Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi daniel0615,
I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re:Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
Hi daniel0615,
Do you get the same problem after resetting the router to factory default and reconfigure it manually?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
Same issue here after resetting the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi daniel0615,
Let me check on this issue you have reported. For now, you may try reverting to v1.0.4.30 firmware or check other browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
tried with IE & Chrome, the same!
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have a idea please if you are working on the firmware go get an xbox one and play gta online for days and have yr ip be ipv6 only the xbox one will be using 2 ipv6 addreses for DNS it wont use ipv4 at all and see what happens
- Mark as New
- Bookmark
- Subscribe
- Permalink
No problem here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just installed V1.0.6.40_1.1.90 and everything is working great. My only problem, as always, when I reset the R7000 with the new firmware, I loose remote connection to the router in my IOS iPhone Genie app. It shows the R7000 but says it's off line. Have deleted and reinstalled the app, but no luck. Kind of sucks. Useing WIFI works fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Installed and working fine, I did not reset to factory defaults, I never did it and I did not have any problem.
My R7000 is acting as pure AP connected to another Router/Firewall running pfSense.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you check thus beta ver is fixed android (opnvpn) connection problem?
Thanks
Please add wol on this router or allow a feature i can telnet the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It works great with IOS OpnVpn. Don't know about Android.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. My mobile is android . So i need android need to be fix.
However. I am not sure are they correct this problem on beta ver.
I think i had mentioned my ptoblem.
Thanks all
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi daniel0615,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi daniel0615,
If pop-up blocker is not enabled but still the same problem, please try the following:
1. Try to use a different computer.
2. Use another device aside from computer.
3. If still the same, please try to revert to v1.0.4.30 and check if the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks everyone, I disabled the popup blocker on chrome, and it works fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI daniel0615,
Glad to know it works now.
