Orbi WiFi 7 RBE973
Reply
Posted by u/BoomBabyDaggers 5 years ago
hayanajen
Follower
So planning on moving to a new 3 story 2000 SQ feet house. The router can only go to one spot which is on the first floor. Question is will I have issues with signal strength? Let me know if there is a better sub for this as well.
Message 1 of 3
Guru
Re: Posted by u/BoomBabyDaggers 5 years ago
Not much to go off.
What NG product are you referring too>?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 3
Guru
Try it.
Reason why is you didn't give us much details.
A single router solution can cover that much area (better if its centrally located) but you might get some lower speeds at the peripheral. For some people, that lower speed isn't an issue as they don't need it. For others, they want peak performance everywhere and would add an extender or switch to a mesh system.
All we can say is try it and see how it works. It might be fine for you or you might find you need more coverage.
I would say to make sure its not in a utility room as they tend to have a lot of hvac that blocks wifi.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 496 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
