Orbi WiFi 7 RBE973
Reply
Problems after updating R8000 firmware
Reenio
I have a pc which only connects to the 2Ghz band but since updating the firmware it has very poor signal & drops out constantly. Other devices are connecting ok? Any known issues or fixes?
Message 1 of 7
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Problems after updating R8000 firmware
Hi @Reenio,
Please perform a factory reset and power cycle on the router after a successful firmware update. I also suggest making sure that the driver for the adapter of the computer is up to date. You may also use the Wi-Fi Analytics feature of the NETGEAR Genie app if you have it installed or any similar program to check for interferences and select the best channel.
Dexter
Community Team
Message 2 of 7
All Replies
DexterJB
NETGEAR Moderator
Hi @Reenio,
Dexter
Community Team
Message 2 of 7
Reenio
Thank you for your response. I'm sorry about replying late. It was a work pc & IT updated the adapter. Works sweet now. Thanks again 🙂
Message 3 of 7
DexterJB
NETGEAR Moderator
Hi @Reenio,
Good to know it is working now and you are welcome.
Dexter
Community Team
Message 4 of 7
rayjos
Nighthawk X6 R8000
Firmware Version
V1.0.2.46_1.0.97
I am not able to establish a wireless SSH connection from my Windows machine to a Linux through the R8000 after updated the firmware. I am able to establish a wired connection. Please suggest how I may recover the functionality. I have setup port forwarding for the server.
I see above that a factory reset my be needed but the user manual does not state how to do this.
How do I perform a factory reset and is there anything else I should check?
Message 5 of 7
rayjos
Re: Problems after updating R8000 firmware, SSH
Nighthawk X6 R8000
Firmware Version
V1.0.2.46_1.0.97
Message 6 of 7
Reenio
Hi Rajos, Are you getting an error message? Im not an expert but I would check to make sure you are getting Internet access through your wifi.
Factory reset instructions are here:
http://kb.netgear.com/app/answers/detail/a_id/25156/~/r8000-faqs
Might be worthwhile posting this as a new question, there may be people who have had similar problems & fixes.
Good luck
Reenio
Message 7 of 7
Discussion stats
  • 6 replies
  • 6066 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
