Orbi WiFi 7 RBE973
Reply
Problems boosting my signal - seems worse than the Virgin Hub 5.
Deanboyo
Follower
Hi, i recently purchased the Nighthawk X6 AC3200 Smart WiFi Router(R8000).
I brought it to try and kill/ get around some black spots in my small one bedroom flat.. unfortunately though after switching my Hub5 (Virgin) into a Modem, and creating the Nighthawk into the router.. its ridiculously slow..
i was getting 920mbps on Virgin Hub 5, just a minor/small part of my flat is getting under 100, because of the old building.
With the Nighthawk, i was lucky to get 600mbps...
any guru's here able to get me set up correctly, boosting the what i currently have.
dean
Message 1 of 3
Guru
Re: Problems boosting my signal - seems worse than the Virgin Hub 5.
R series routers may not ever see anything near 900Mpbs on 5Ghz Wifi. Its of older generation hardware and support. Most you might see is around 600-700Mpbs depending upon wifi devices you connect and there design and support and limitations between both devices and this model router.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 3
The original hub should be more than enough to swamp a one-bedroom flat with wifi.
How did you turn the Hub5 "into a modem"? It is more than simply unplugging things and turning off the wifi on the hub.
virgin hub 5 bridge mode - Google Search
and
Solved: Advice on how to put Hub 5 into Modem mode & what ... - Virgin Media Community - 4993448
You won't get 600 Mbps with wifi, let alone 920 Mbps. That's faster than most wifi clients can manage.
Older wifi clients on 2.4 GHz may well max out at 100 Mbps.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 356 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
