Orbi WiFi 7 RBE973
Reply
R6230 download speed dropped after hard reset
Domborza
Follower
I've been trying to play NBA2k22 on my xbox but it said i needed to have my NAT open, which I figured out,  and to have a static IP, which i couldnt figure out. I thought i messed somthing up when the NAT on the router is set to open but my xbox says it is now strict and double NAT detected or somthing. So I hard reset the router and now my download speed went from 49mbps to about 15mbps so im not sure what to do now. Should I hard reset again?
Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
Message 1 of 2
Guru
Re: R6230 download speed dropped after hard reset
Some more details on your setup helps.
1. what modem/gateway is the router connected to?
2. firmware on the router?
3. is the xbox wired in? wireless?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 386 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
